- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]induction proof bis
- Date: Fri, 12 May 2006 19:10:59 +0200
Hello,
I thank you for your answer.
but I'm sorry, I was mistaken in my problem.
I have a transitivity problem with copy definition.
I try to proof it for one week. I don't have a new idea.
If you have an indication, an idea or other
Thanks very much,
Martin
Require Import ZArith.
Parameter memory : Set.
Parameter valeur : Set.
Parameter lecture : memory -> nat -> nat -> valeur -> Prop.
(* offset <= idx < offset + len *)
Definition check
(offset: nat) (idx: nat) (len: nat) : bool :=
(Zle_bool (Z_of_nat offset) (Z_of_nat idx))
&& (Zlt_bool (Z_of_nat idx) (Z_of_nat (offset+len))).
Definition copy
(min mout : memory) (mem_length: nat)
(adrSrc: nat) (adrDest: nat) (offset: nat) (len:nat) : Prop :=
forall idx:nat,
idx<mem_length ->
forall val:valeur,
lecture min adrSrc idx val ->
if (check offset idx len)
then
lecture mout adrDest idx val
else
(lecture min adrDest idx val) <->
(lecture mout adrDest idx val).
Lemma copy_trans :
forall min mem mout mem_length adrSrc adrDest offset l1 l2,
copy min mem mem_length adrSrc adrDest offset l1 ->
copy mem mout mem_length adrSrc adrDest (offset+l1) l2 ->
copy min mout mem_length adrSrc adrDest offset (l1+l2).
- [Coq-Club]induction proof bis, topwl
