[Coq-Club]Problems proving equality of proof terms of inductively defined predicate.
chronological Thread
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]Problems proving equality of proof terms of inductively defined predicate.
- Date: Sun, 4 Jun 2006 15:49:36 +0200 (CEST)
- Importance: Normal
Greetings.
Is the following provable? If it is, how? If it isn't, why not? :
Inductive P : nat -> Prop := C0 : P 0 | C1 : P 1.
Theorem A: forall (x: P 0), x = C0.
As soon as I try to do case analysis or induction on x with the intention
to reveal that it can only be C0, I get "Cannot solve a second-order
unification problem". Coq Faq item 171 suggests helping Coq using the
"pattern" tactic, but I can't find a way to do that here. I've also tried
rephrasing the equality using Eqdep, but always seem to end up with the
same problem as above.
Had P been of type nat -> Set I could have used JMeq:
Require Import JMeq.
Inductive P : nat -> Set := C0 : P 0 | C1 : P 1.
Lemma H: forall (n: nat) (x: P n), n = 0 -> JMeq x C0.
Proof.
induction x.
reflexivity.
intro.
discriminate.
Qed.
Theorem B: forall (x: P 0), x = C0.
Proof.
intro.
apply JMeq_eq.
apply H.
reflexivity.
Qed.
However, JMeq doesn't seem to work for things in Prop.
As a side note, if there's a proof of B that does not rely on JMeq (and
its axiom) I'd also be very interested in that.
Any help is appreciated.
Thanks,
Eelis
- [Coq-Club]Problems proving equality of proof terms of inductively defined predicate., Eelis van der Weegen
