- From: Santiago Zanella B�guelin <szanella AT fceia.unr.edu.ar>
- To: <nouvid-coq AT yahoo.fr>, <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club]Type system in Coq
- Date: Wed, 7 Jun 2006 00:49:30 -0300
Fabrice,
I think the problem is that the induction principle Coq generates for your definiton of Typ cannot be used to prove your goal:
Typ_ind
: forall P : forall t : Trm, Typ t -> Prop,
P trm axiom -> forall (t : Trm) (t0 : Typ t), P t t0
In order to apply this induction principle in your goal, a predicate of the form (fun (t:Trm)(x:Typ t) => x = axiom) may eventually have to be constructed. Such a predicate cannot be typed because the Coq type system is not able to determine that x must have type Typ trm (although it can be proved). You may either (1) restate your definition of Typ, (2) use dependent equality, or (3) assume an ad hoc induction principle. It seems you should go for (1).
(1)
Inductive Typ : Trm->Set :=
axiom : forall t:Trm, Typ t.
Goal forall t:Trm, forall x y:Typ t, x=y.
destruct x; induction y; trivial.
(2) See the Coq.Logic.Eqdep library.
Require Import Eqdep.
Inductive Trm : Set :=
trm : Trm.
axiom : Typ trm.
Lemma dep_eq : forall t:Trm, forall x y:Typ t, eq_dep Trm Typ t x t y.
destruct x; destruct y; trivial.
Qed.
Goal forall t:Trm, forall x y:Typ t, x = y.
intros t x y; exact (eq_dep_eq Trm Typ t x y (dep_eq t x y)).
(3)
Axiom Typ_trm_ind :
forall P : Typ trm -> Prop,
P axiom -> forall (x : Typ trm), P x.
destruct x; apply Typ_trm_ind; trivial.
Hope this helps,
Santiago Zanella Béguelin
----- Original Message ----- From: "Fabrice Lemercier" <nouvid-coq AT yahoo.fr>
To:
Sent: Tuesday, June 06, 2006 10:16 PM
Subject: [Coq-Club]Type system in Coq
Hello,
I am formalizing a language and its type system in
Coq. Follow a simple example which is sufficient to
exhibit my problem.
The syntax of my language (consisting of just one
constant) is given by the following inductive
definition:
trm : Trm.
There is only one typing rules (stating that my
constant is well typed) given by:
axiom : Typ trm.
Now, I'd like to prove a fundamental property of my
type system which is that for each term there is a
unique type derivation:
I know that if I put Typ in Prop instead of Set, then
I can prove the above statement by using proof
irrelevance in classical logic. But I put them in Set
because I want them to be extracted. What can I do?
Thanks,
Fabrice
__________________________________________________
Do You Yahoo!?
En finir avec le spam? Yahoo! Mail vous offre la meilleure protection possible contre les messages non sollicités
http://mail.yahoo.fr Yahoo! Mail
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club]Type system in Coq, Fabrice Lemercier
- Re: [Coq-Club]Type system in Coq, Santiago Zanella Béguelin
Lionel Elie Mamane
- RE : Re: [Coq-Club]Type system in Coq,
Fabrice Lemercier
- Re: RE : Re: [Coq-Club]Type system in Coq, Roland Zumkeller
- Re: RE : Re: [Coq-Club]Type system in Coq, Lionel Elie Mamane
- Re: RE : Re: [Coq-Club]Type system in Coq, Frederic Blanqui
Fabrice Lemercier
