- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]Matching let expressions in Ltac
- Date: Fri, 14 Jul 2006 16:03:57 +0100
- Organization: School of Informatics, The University of Edinburgh
Hi,
I wish to write a Coq tactic that matches goals that are similar to that of
the following statement:
Definition test : (let (a,b) := (0, 1) in a=0).
I've tried the following tactic when a proof of the above statement is
started:
Ltac m1 :=
match goal with
| |- context [let _ := _ in _] => idtac "Match!"
end.
And it fails to match. However, it matches goals of the form "(let a := 0 in
a=0)". I then tried:
Ltac m2 :=
match goal with
| |- context [let (_,_) := _ in _] => idtac "Match!"
end.
Coqide replies "User error: Not supported pattern" for the pattern with the
let expression containing the pair. How can I write a tactic that matches
goals of this form?
Also, how would I go about outputting matched patterns in Ltac for debug
purposes? For example, given the following:
Ltac m3 :=
match goal with
| |- context [let _ := _ in ?X] => idtac X
end.
I would like this to output what X was matched with but idtac wants a string
as input.
Thanks,
Sean
- [Coq-Club]Matching let expressions in Ltac, Sean Wilson
- Re: [Coq-Club]Matching let expressions in Ltac, Adam Chlipala
