coq-club - Re: [Coq-Club]Creating and using mutual induction schemes
chronological Thread
  • To: "Andrew Gacek" <andrew.gacek AT gmail.com>
  • Cc: Coq-Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club]Creating and using mutual induction schemes
  • Date: Wed, 26 Jul 2006 02:57:21 +0200
On Tue, 25 Jul 2006 15:49:59 -0500 "Andrew Gacek"
 wrote:
>  Inductive term : Set :=
>   | one : term
>   | app : term -> term -> term
>   | lam : term -> term
>   | clos : term -> env -> term
>   with env : Set :=
>   | id : env
>   | shift : env
>   | cons : term -> env -> env
>   | merge : env -> env -> env.
>  Scheme term_env_ind := Induction for term Sort Prop
>   with env_term_ind := Induction for env Sort Prop.
> Theorem Inverse : forall (t : Sigma.term) (e : Sigma.env),
>   susp_to_sigma_term (sigma_to_susp_term t) = t /\
>   susp_to_sigma_env (sigma_to_susp_env e) (sigma_to_susp_nl e) = e.
> Have I stated the induction schemes correctly?
yes
> Is the theorem in
> proper form to apply those schemes? If so, how?
No, you have to chose one of the two properties as "the one you prove"
and use the other as a parameter of the principle you will use (see the
type of term_env_ind : it takes two predicates as arguments BUT the
conclusion is about one of them). This should give you the idea:
  | one : term
  with env : Set :=
  | id : env
  | shift : env
(* don't know all these*)
 Variable sigma : Set.
 Variable sigma_to_susp_term : term -> sigma.
 Variable sigma_to_susp_env : env -> sigma.
 Variable susp_to_sigma_term : sigma -> term.
 Variable susp_to_sigma_env : sigma -> sigma -> env.
 Variable sigma_to_susp_nl : env -> sigma.
Theorem Inverse : forall (t : term), susp_to_sigma_term (sigma_to_susp_term
t) = t.
  intros t.
  induction t using term_env_ind
    with (P0:=fun e:env => susp_to_sigma_env (sigma_to_susp_env e)
(sigma_to_susp_nl e) = e).
> Thanks,
> Andrew Gacek
