- From: Pierre Letouzey <Pierre.Letouzey AT pps.jussieu.fr>
- To: Lionel Elie Mamane <lionel AT mamane.lu>
- Subject: Re: [Coq-Club]request
- Date: Mon, 14 Aug 2006 12:27:27 +0200
- Resent-date: Mon, 14 Aug 2006 14:27:44 +0200
- Resent-from: Pierre.Letouzey AT pps.jussieu.fr
- Resent-message-id: <20060814122744.GA4947 AT uranium.pps.jussieu.fr>
- Resent-to: coq-club AT pauillac.inria.fr
On Mon, Aug 14, 2006 at 10:01:03AM +0200, Lionel Elie Mamane wrote:
> On Fri, Aug 11, 2006 at 04:20:38PM -0400,
> roconnor AT theorem.ca
> wrote:
> >> I am a newcomer to Coq and would like to know how to define
> >> sets of the form
> >> X={1,2,3}.
> > There are multiple represations of sets in Coq. It is most common
> > to represents sets as predicates.
> Alternatively, for finite sets, a list/heap/... can be adequate is
> some cases. (If you use lists, you'll want to use another equality
> than the Coq equality as your main interesting equality.)
If indeed you can limit yourself to finite sets, then you might be
interested by the library FSet/FMap I've recently added to Coq. It
still have some sharp edges and no documentation yet apart from the
source files, but it's already quite usable. Below is a session done
with Coq 8.1beta...
Best regards,
Pierre Letouzey
(* Let's use fast integers. *)
Require Import ZArith.
Open Scope Z_scope.
(* Some examples of ordered types, including Z *)
Require OrderedTypeEx.
(* One implementation of finite sets over an ordered type, based on lists *)
Require FSetList.
(* Other possibility: FSetAVL, heavier for Coq but more efficient *)
(* We combine the two in a specialized module for sets of integers *)
Module IntSet := FSetList.Make(OrderedTypeEx.Z_as_OT).
Import IntSet.
(* To have a rough idea of what's available in this IntSet: *)
Print IntSet.
(* Your set: *)
Definition X := add 1 (add 2 (add 3 empty)).
(* Idem, with a nice notation: *)
Infix "++" := add (at level 30, right associativity).
Definition X' := 0++2++4++empty.
(* Some examples of computation: *)
Eval compute in (cardinal X).
Eval compute in (elements (inter X X')).
- [Coq-Club]request, David de Villiers
- Re: [Coq-Club]request,
roconnor
Lionel Elie Mamane
- Re: [Coq-Club]request, Pierre Letouzey
Lionel Elie Mamane
roconnor
