coq-club - [Coq-Club]Polymorphic lists and functions
chronological Thread
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club]Polymorphic lists and functions
  • Date: Wed, 6 Sep 2006 12:40:52 -0700 (PDT)
Hi guys!!!!
I have been grappling with polymorphism in Coq for a while. So thought a concrete example might make it easier for people to answer.
Let's say I have:
Inductive policy_kind:Set :=
    policy_a | policy_b.
Record policy_A:Set := A {a_def : bool, a_cur:bool}.
Record policy_b:Set := B {b_def: nat, b_max:nat,b_cur:nat}.
What should be the correct definition for 'policy' if I want to do something like the following:
Definition policy (k:policy_kind) (data:list <?>) : <?> :=
    match k with
       | policy_a => A (nth 0 data) (nth 1 data) (*nth must return a bool*)
       | policy_b => B (nth 0 data) (nth 1 data) (nth 2 data) (*nth must return a nat*)
end.
I know I can do it differently, but I want to do it this way so that the accessor functions are auto generated.
There may be syntax errors in the above, but, basically I need to figure out what would the terms be that should replace the '?" in the above definition.
Thanks in anticipation.
