- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club]ProofGeneral new dev release -- for coq 8.1 users
- Date: Tue, 12 Sep 2006 22:16:46 +0200
Hello,
A new development release of ProofGeneral is available at
http://zermelo.dcs.ed.ac.uk/devel
New features / Improvements :
*** No more support for coq 7.x
*** Much better PG/Coq synchronizing system for coq >= 8.1
*** error highlighting
*** coq 8.0 compatibility mode
*** Much better indentation
*** new coq-insert-tactic and coq-insert-command functions
*** New variables coq-user-commands-db and coq-user-tactics-db
*** automatic insertion of "match...with" for a given type
*** Local Variables List semi automatic filling
*** Better font-lock coloration
*** new "queries" menu
Details below,
bug reports are welcome
(Pierre.Courtieu AT cnam.fr)
Cheers,
Pierre Courtieu
Synchronization is not based on script parsing anymore, which
makes it much more reliable.
In particular you don't need to set
coq-user-state-changing-commands and others anymore (was needed
for your own tactics/commands). See below coq-user-commands-db.
Coq v8.0 is still supported, if for some reason PG does not see
that your coq version is a 8.0 (read *Message* after loading a .v
file), then set variable coq-version-is-V8-0 to t in your emacs
init file. Otherwise PG will hang at first line when scripting.
When scripting, error with location information are parsed and the
corresponding part of the scripting buffer is highlighted. Inspired
from coqide.
If coq does not detect the good coq version at startup put one of
the following in your .emacs:
(setq coq-version-is-V8-1 t) or (setq coq-version-is-V8-0 t)
Default is now 8.1 (if no coqtop is found in the path when loading
the first .v file).
More robust. nested comments are OK even in xemacs. Still
slow on big files.
indent-region won't touch comments, but indenting comments with
tab (indent-according-to-mode) will.
These two functions allow to insert a tactic or command with
completion in the mini-buffer.
User defined tactics/commands information. See C-h v
coq-syntax-db for syntax. It is not necessary to add your own
tactics here if you have coq v8.1 (it is not needed by the
synchronizing/backtracking system). You may however do so for the
following reasons:
1 your tactics/commands will be colorized by font-lock
2 your tactics/commands will be added to the menu and to completion
when calling coq-insert-tactic/command (see below)
3 you may define an abbreviation for your tactic/command.
This coqide great feature has been added.
Local Variables Lists are used to set coq program name and arguments
persistently for a given file. The menu entry "set coq prog
persistently" helps you to define or change the values in this list
(which are store as a comment at the end of the file, see info
manual at node ((emacs)File Variables).
- [Coq-Club]ProofGeneral new dev release -- for coq 8.1 users, Pierre Courtieu
