coq-club - Re: [Coq-Club]; Notations
chronological Thread
On Tue, 17 Oct 2006, Hugo Herbelin wrote:
 Moreover, having a notation accepted does not ensure by any means
that the added parsing rule does not conflict with other rules of the
grammar. For instance, if you add a notation of the form "x ; y", what
you probably did, it definitively hides the parsing rule for record
fields. Coq is constrained with the LL constraints of its underlying
extensible parsing tool Camlp4.
Thanks. Would it be reasonable to disallow notations that conflict with the normal Coq language, or is it not worth it because there is a more general problem of notations from different developments conflicting with each other?
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
