coq-club - Re: [Coq-Club]Tactics inside functors
chronological Thread
  • From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
  • To: necula AT eecs.berkeley.edu (George Necula)
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]Tactics inside functors
  • Date: Tue, 31 Oct 2006 18:07:21 +0100 (MET)
Hi,
>  I was able to use a tactic defined in a module. But if I want to
> ascribe a module type to the module, how can I declare the tactic in the
> module type?
>  Is it possible to define tactics inside functors?
Declaring a tactic in a module type is done the same way as declaring a
tactic in a module. For instance
Module Type U.
Ltac myintro := intro.
Tactic Notation "myassumption" := assumption.
End U.
Then, there is no subtyping for tactics. So, if you ascribe a module
type to a module, only the tactics declared in the module type are
available (if a tactic with a same name exists in the module, it is
simply discarded even if the body of the tactic differs). For
instance:
Module M : U.
End M.
Goal True->True.
M.myintro.
Import M. (* to import the tactic notation *)
myassumption.
Qed.
As a consequence, I don't see how to have an explicitly typed functor
that defines a tactic dependent of a tactic defined in the argument of
the functor, if this is the question.
Best regards,
Hugo Herbelin
