- From: Hugo Herbelin <herbelin AT pauillac.inria.fr>
- To: necula AT eecs.berkeley.edu (George Necula)
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Possible bug in coqdep
- Date: Fri, 3 Nov 2006 17:22:42 +0100 (MET)
Hi,
> If my module contains
> Require Import List Elists.
> then coqdep misses Elists. If instead I break that line into separate
> Require Import commands, then get the correct dependencies.
Yes, coqdep does not support this new, still undocumented, extension
of the syntax of Require yet. It does however in the V8-0-bugfix
subversion branch downloadable from http://coq.gforge.inria.fr. Also,
a 4th patch level version of Coq 8.0 that, among other bug fixes,
includes a coqdep compatible with this feature will be made available
within a couple of weeks on the web site of Coq.
Best regards,
Hugo Herbelin
- [Coq-Club]Possible bug in coqdep, George Necula
- Re: [Coq-Club]Possible bug in coqdep, Hugo Herbelin
