coq-club - [Coq-Club]Generating induction principles
chronological Thread
  • From: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club]Generating induction principles
  • Date: Mon, 20 Nov 2006 10:23:26 -0500
Hi,
Coq'Art, section 14.3.3, gives the following example of an inductive datatype for which the default induction principle is useless and for which the Scheme command also does not help.
Require Import List.
Inductive ltree (A : Set) : Set :=
  lnode : A -> list (ltree A) -> ltree A.
Check ltree_ind.
ltree_ind
     : forall (A : Set) (P : ltree A -> Prop),
       (forall (a : A) (l : list (ltree A)), P (lnode A a l)) ->
       forall l : ltree A, P l
ltree_ind overlooks the fact that the list in lnode may have ltree subterms that deserve induction hypotheses. One solution to this problem is to build the induction principle by hand using Fixpoint.
My question is: with the release of Coq 8.1gamma, is there any automatic support for generating the "correct" induction principle for datatypes such as ltree? Is such support being worked on? I didn't see anything in the CHANGES file, but it's possible I missed something.
Thanks,
Brian
