- To: Mateus Oliveira <mateus.oliveira AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]problems with listSet
- Date: Tue, 21 Nov 2006 10:24:07 -0800
You need to specify an equality procedure for any use of that function, which the error message expresses quite nicely once you are expecting such things. :) Try running "Check set_union" to see exactly what its type is. Remember that, since set_union and others are defined inside a Section that declares a Variable and Hypothesis, these are extra arguments for all the Section's inhabitants.
Mateus Oliveira wrote:
I'm having problems with the use of functions defined in
the ListSet library. For example, the following definition
causes an error:
Require Export ListSet.
Definition test_union(l1 l2:set nat):set nat:= set_union l1 l2.
Error: In environment
l1: set nat
l2: set nat
The term "l1" has type "set nat" while it is expected to have type
"forall x y : ?1, {x=y} + {x<>y}"
I don't understand why l1 must not have type "set nat" in this example.
What should I do to make this simple definition be accepted?
- [Coq-Club]problems with listSet, Mateus Oliveira
- Re: [Coq-Club]problems with listSet, Adam Chlipala
- [Coq-Club]Re: problems with listSet, Mateus Oliveira
