- To: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Modules in Coq 8.1gamma - Strange errors
- Date: Wed, 29 Nov 2006 11:24:57 +0100
Brian E. Aydemir wrote:
Hi everyone,Hi,
I'm working in Coq 8.1gamma. The errors I'm seeing from the module system are confusing to me, so I'm hoping that I can find some help from this list. As far as I can tell, I must be misunderstanding something important about the difference between ":" and "<:" when ascribing types to modules. Two small examples showing exactly what confuses me are below.
Thanks,
Brian
All of my examples assume the following libraries are imported:
Require Import DecidableType.
Require Import DecidableTypeEx.
EXAMPLE 1: Consider the following code.
Module Type Test.
Declare Module E : DecidableType.
End Test.
Module Make (X : DecidableType) <: Test with Module E := X.
Module E : DecidableType := X.
End Make.
The "End Make" results in the following error: "User error: Signature components for label t do not match". My question(s): where is this label t coming from and why? If I change the line
to
Module E <: DecidableType := X.
this example goes through without problem. I'm not sure what the meaningful difference here is. In both cases, E is defined by a module expression which has an appropriate module type, and I don't see what the visibility of the things inside E has to do with anything.
Module E : DecidableType := X is a generative declaration. So E.t is not convertible to X.t.
The constraint Module E := X is therefore not satisfied.
On the other hand, Module E <: DecidableType := X is not generative, E is an alias for X, with a check that its signature can be coerced to DecidableType. In this case the constraint is satisfied.
This one looks like a bug to me. Unless someone finds an explanation, I suggest you file a bug report on coq-bugs.
EXAMPLE 2: Extending the above example, consider the following.
Module Type Test.
End Test.
End Make.
Module N' : DecidableType := Nat_as_DT.
Module Q : Test with Module E := N' := Make N'.
That works without problem. If I change the line
to
Module N' <: DecidableType := Nat_as_DT.
the definition of Q gives me the error "User error: No such label OF". Why is this the case? Trying to define Q directly, via
Module Q : Test with Module E := Nat_as_DT := Make Nat_as_DT.
results in the same error.
Cheers,
Bruno Barras.
- [Coq-Club]Modules in Coq 8.1gamma - Strange errors, Brian E. Aydemir
- Re: [Coq-Club]Modules in Coq 8.1gamma - Strange errors, Bruno Barras
