coq-club - Re: [Coq-Club]proven false
chronological Thread
  • From: Pierre Cast�ran <pierre.casteran AT labri.fr>
  • To: David de Villiers <davidc1 AT ananzi.co.za>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club]proven false
  • Date: Tue, 19 Dec 2006 22:00:21 +0100
Quoting David de Villiers
<davidc1 AT ananzi.co.za>:
Hi,
I have been searching for a way to prove a statement false.
In the CoqArt book, p118 is the following unsatisfactory
example:
Hypothesis ff:False.
Lemma ex1: 220=284.
Proof.
  apply False_ind.
  exact ff.
Qed.
Hello,
 The example page 118 is *NOT* about proving some contradiction, but
about using (i.e. eliminating) some contradiction for deriving any statement.
In general, this kind of argument is used within a section, as in the example
you point out. This particular example is a proof of the proposition
False -> 220=284, the proof term of which is
(fun ff:False => False_ind (220=284) ff)
It is unsatisfactory because I tried the following and
noticed the identicality.
Lemma ex1: 220=220.
Proof.
  apply False_ind.
  exact ff.
Qed.
Ok, False -> 220=220 is also provable,
We can give a proof-term similar to the preceding one:
(fun ff:False => False_ind (220=220) ff)
But, since 220=220 is always provable, you can get another proof
which doesn't use any specific property of False.
Check (fun (p: False) => refl_equal 220).
False -> 220=220
 Notice that any proposition of the form P->220=220 is also
provable, with the proof-term (fun (p:P) => refl_equal 220)
My idea runs as follows:
Prove that:
True XOR X, and you have proven X false.
For XOR I use the following logically equivalent
formulation:
(True /\ ~X) \/ (X /\ ~True).
The result:
Theorem no_eq: (True /\ ~(7=11)) \/ ((7=11) /\ False).
Proof.
  auto.
Qed.
Any other ideas?
Well, If you want to prove some proposition X is false, you simply
have to prove ~X  (i.e. X -> False).
But don't confound ~X (X -> False)  with False -> X,
False -> X is always provable, for any proposition X, so does not express
anything about X.
Pierre
Ciao.
David.
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Pierre Castéran
