- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club]Set comprehensions in Coq?
- Date: Sat, 03 Mar 2007 19:33:10 -0800
Peter Hawkins wrote:
Inductive pointguard : nat -> formula -> Prop :=
| pg_base: pointguard n0 f_true.
| pointguard : ... what goes here to specify the conjunction of
pgmerge for each n? ...
with pgmerge : nat -> formula :=
| pgmerge_elem: forall p1 p2 f1 f2,
pointguard p1 f1 -> cfg p1 p2 f2 -> pgmerge p2 (f_and f1 f2).
Now, I expect I can't actually write that in Coq since it doesn't know
about the graph property in question and won't understand that the
definition is sane. I'm guessing that at best I can define this
axiomatically.
It looks to me like the central issue isn't the ability to use "set comprehensions"; what matters is that the sets you care about are finite, so that it makes sense to define the conjunctions of their images under a function. (The meaning of "and" in the Coq standard library isn't such that infinite conjunctions are necessarily representable in Prop, or at least it isn't obvious to me how to prove otherwise.)
However you specify the finiteness of your graph, you should be able to prove that every node of the graph is below some specific natural number. With that, it should be easy to define a relation that iterates through all natural numbers and merges for only those that are adjacent to the current node.
You could also define a general abstraction of finite sets of natural numbers, where you have a fold operation (generalization of your merge) that depends on knowing that a bound on the set size exists.
- [Coq-Club]Set comprehensions in Coq?, Peter Hawkins
- Re: [Coq-Club]Set comprehensions in Coq?,
Adam Chlipala
Peter Hawkins
Adam Chlipala
Peter Hawkins
- Re: [Coq-Club]Set comprehensions in Coq?, Adam Chlipala
- Re: [Coq-Club]Set comprehensions in Coq?, Benjamin Werner
Peter Hawkins
Adam Chlipala
Peter Hawkins
Adam Chlipala
