- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club]Compilation error in coqide (8.1)
- Date: Thu, 8 Mar 2007 17:05:48 +0000
Hi,
When I try to compile coq 8.1 with the IDE enabled, I get the following
compilation error:
OCAMLC ide/undo.ml
The implementation ide/undo.ml does not match the interface ide/undo.cmi:
Class declarations do not match:
class undoable_view :
([> Gtk.text_view ] as 'a) Gtk.obj ->
object
val history : action Stack.t
val nredo : action Stack.t
val obj : 'a Gtk.obj
val redo : action Queue.t
method add_child_at_anchor : GObj.widget -> GText.child_anchor -> unit
method add_child_in_window :
child:GObj.widget ->
which_window:Gtk.Tags.text_window_type -> x:int -> y:int -> unit
method as_view : Gtk.text_view Gtk.obj
method as_widget : Gtk.widget Gtk.obj
method backward_display_line : GText.iter -> bool
method backward_display_line_start : GText.iter -> bool
method buffer : GText.buffer
method buffer_to_window_coords :
tag:Gtk.Tags.text_window_type -> x:int -> y:int -> int * int
method clear_undo : unit
method coerce : GObj.widget
method connect : GText.view_signals
method cursor_visible : bool
method destroy : unit -> unit
method drag : GObj.drag_ops
method private dump_debug : unit
method editable : bool
method event : GObj.event_ops
method forward_display_line : GText.iter -> bool
method forward_display_line_end : GText.iter -> bool
method get_border_window_size :
[ `BOTTOM | `LEFT | `RIGHT | `TOP ] -> int
method get_iter_at_location : x:int -> y:int -> GText.iter
method get_iter_location : GText.iter -> Gdk.Rectangle.t
method get_line_at_y : int -> GText.iter * int
method get_line_yrange : GText.iter -> int * int
method get_oid : int
method get_window : Gtk.Tags.text_window_type -> Gdk.window option
method get_window_type : Gdk.window -> Gtk.Tags.text_window_type
method indent : int
method justification : Gtk.Tags.justification
method left_margin : int
method misc : GObj.misc_ops
method move_child : child:GObj.widget -> x:int -> y:int -> unit
method move_mark_onscreen : GText.mark -> bool
method move_visually : GText.iter -> int -> bool
method pixels_above_lines : int
method pixels_below_lines : int
method pixels_inside_wrap : int
method place_cursor_onscreen : unit -> bool
method redo : bool
method right_margin : int
method scroll_mark_onscreen : GText.mark -> unit
method scroll_to_iter :
?within_margin:float ->
?use_align:bool ->
?xalign:float -> ?yalign:float -> GText.iter -> bool
method scroll_to_mark :
?use_align:bool ->
?xalign:float -> ?yalign:float -> GText.mark -> unit
method set_border_window_size :
typ:[ `BOTTOM | `LEFT | `RIGHT | `TOP ] -> size:int -> unit
method set_buffer : GText.buffer -> unit
method set_cursor_visible : bool -> unit
method set_editable : bool -> unit
method set_indent : int -> unit
method set_justification : Gtk.Tags.justification -> unit
method set_left_margin : int -> unit
method set_pixels_above_lines : int -> unit
method set_pixels_below_lines : int -> unit
method set_pixels_inside_wrap : int -> unit
method set_right_margin : int -> unit
method set_wrap_mode : Gtk.Tags.wrap_mode -> unit
method starts_display_line : GText.iter -> bool
method undo : bool
method visible_rect : Gdk.Rectangle.t
method window_to_buffer_coords :
method wrap_mode : Gtk.Tags.wrap_mode
end
does not match
Gtk.text_view Gtk.obj ->
object
val obj : [> Gtk.text_view ] Gtk.obj
method indent : int
method redo : bool
?use_align:bool ->
?use_align:bool ->
method undo : bool
end
One parameter has type ([> Gtk.text_view ] as 'a) Gtk.obj = 'a Gobject.obj
but is expected to have type
Gtk.text_view Gtk.obj = Gtk.text_view Gobject.obj
Type 'a = [> `container | `gtk | `textview | `widget ]
is not compatible with type
Gtk.text_view = [ `container | `gtk | `textview | `widget ]
make: *** [ide/undo.cmo] Error 2
Any ideas? I'm running Debian Linux; not sure what other information
would be relevant; ocalmc reports version 3.09.2; I have the Gtk 2
bindings for Ocaml installed (Debian package liblablgtk2-ocaml-dev,
version 2.6.0-7).
Edsko
- [Coq-Club]Compilation error in coqide (8.1), Edsko de Vries
- Re: [Coq-Club]Compilation error in coqide (8.1), Ralph Matthes
- Message not available
Edsko de Vries
- Re: [Coq-Club]Compilation error in coqide (8.1), Samuel Mimram
Edsko de Vries
