coq-club - [Coq-Club]Modules and Hints
chronological Thread
  • From: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club]Modules and Hints
  • Date: Tue, 27 Mar 2007 23:40:25 -0400
Hi everyone,
I'm a little confused about how Modules and Hints interact. The following example illustrates my problem.
Module Type FOO.
  Parameter P : nat -> Prop.
  Axiom P_true : forall n, P n.
  Hint Resolve P_true.
End FOO.
Declare Module Foo : FOO.
Theorem baz : forall n, Foo.P n.
info auto. (* why is P_true in the hints database here? *)
Qed.
In the proof of baz, I was expecting that "P_true" would _not_ be in the Hints database. Print HintDb and the behavior of auto say that I'm wrong. (I would expect, however, that if I had done Import Foo, then P_true would be in the database.)
My questions now:
[1] Suppose that I'm not allowed to change FOO. Is there some way I could have declared Foo such that P_true would _not_ end up in the Hints database.
[2] Is the behavior I'm seeing actually the intended behavior? I thought the reference manual said that this shouldn't actually happen, but I can't seem to find the spot where I might have read that.
Thanks for any help,
Brian
