coq-club - [Coq-Club] Re: coqdoc and UTF8
chronological Thread
  • From: Geoffrey Alan Washburn <geoffw AT cis.upenn.edu>
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Re: coqdoc and UTF8
  • Date: Wed, 11 Apr 2007 23:22:20 -0400
Edsko de Vries wrote:
I have a coq file (.v) with lots of unicode in it. When I try to generate the
latex file using
coqdoc --latex -g --inputenc utf8x stlu.v
and then try to compile the Latex, I get
! Package utf8x Error: Malformed UTF-8 sequence.
I'm not sure about this.
If I use the coqdoc --utf8 option instead, I get a similar error
! Package inputenc Error: Unicode char
\u8:ᅵ\check@icr\expandafter
 not
set up f or use with LaTeX.
Any ideas?
The above error message means that LaTeX does not know how to interpret the given Unicode glyph. Some mappings are provided by default, but many Unicode glyphs are not given a default behavior. Perhaps someone else has done something like this for the glyphs you are using. If not, for each glyph you need to define you will need to add a LaTeX commmand like
\DeclareUnicodeCharacter{03B1}{%my mapping for α%}
where the first argument is the hexadecimal identity of the Unicode glyph and the second argument is arbitrary LaTeX. For example, I use
\DeclareUnicodeCharacter{03B1}{\textalpha}
where \textalpha is a macro that selects the α gylph from the appropriate font.
