- From: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
- To: Nassima.Izerrouken AT enseeiht.fr
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Coqide under Mac Os
- Date: Thu, 12 Apr 2007 09:15:45 -0400
On Apr 12, 2007, at 8:55 AM,
wrote:
I'm running Coq under Mac Os machine, and then i want to use the graphical
editor Coqide, it's installed but the following exception appear at
launch:
Fatal error: exception Gtk.Error("GtkMain.init: initialization failed
ml_gtk_init: initialization failed")
Someone has an idea?
I've seen that exception when X11.app is not running. Since CoqIDE is an X11 application, you need to first make sure that X11.app is running. Second, you need to make sure that the DISPLAY environment variable is set appropriately. If you start CoqIDE from an xterm, this should already be taken care of; if you start it from, say, Terminal.app, you may need to set DISPLAY to :0.
In any event, that's my guess.
Hope that helps,
Brian
- [Coq-Club] Coqide under Mac Os, Nassima . Izerrouken
- Re: [Coq-Club] Coqide under Mac Os, Brian E. Aydemir
