- To: coq mailing list <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] How to implement arbitrary object factories ....
- Date: Wed, 18 Apr 2007 07:25:53 -0700 (PDT)
I posted the following a couple days ago and re-posting just to make sure it made it to the list.
This may be too trivial, but I just can't get the typing quite right.
I need to do something like the following in order to have an object factory that parses through serialized data (i.e. a stream of bytes) and constructs the appropriate objects. I'd appreciate any help.
I would also appreciate any pointers to relevant work already done or some reading material that describes how to implement such arbitrary object factories.
Require Import List.
Record a:Set:=A{a':nat}.
Record b:Set:=B{b':nat;b'':list a}.
Record c:Set:=C{c':nat;c'':b}.
Inductive obj_enum:Set:=
| A'
| B'
| C'
Definition obj_kind (o:obj_enum) :=
match o with
| A' => a
| B' => b
| C' => c
end
Fixpoint create_obj (l:list nat) (o:obj_enum) {struct o}:=
match o return (obj_kind o) with
| A' => (A (nth 0 l 0))
| B' => (B (nth 0 l 1) (create_objs (tail l) A'))
| C' => (C (nth 0 l 2) (create_obj (tail l) B'))
end
with create_objs (l:list nat) (o:obj_enum) {struct l}:=
match l with
| nil => nil
| n :: l' => (create_obj (n::nil) o) :: (create_objs l' o)
end
| A'
| B'
| C'
match o with
| A' => a
| B' => b
| C' => c
end
end
match l with
| nil => nil
end
- [Coq-Club] How to implement arbitrary object factories ...., Satrajit Roy
