- From: Florent Becker <florent.becker AT ens-lyon.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] inversion, simple inversion and dependent rewrite
- Date: Tue, 24 Apr 2007 22:28:54 +0200
Hi all,
I am currently toying with a formalization of graph theory, and I can't help tripping as I catch my own feet into the exposed guts of inversion, which is a little gore.
Here is a less horror-movie-graphic and more formal definition of the problem. I define graphs inductively independently of any "set of nodes" (contrarily to what J Duprat did in his library). The definition is as follows:
Inductive graph : nat -> Set :=
| gnil : graph 0
| gcons : forall (n : nat) (l : Bvector n), graph n -> graph (S n).
The Bvector is the adjacency list of the vertex being added, restricted to the previous vertices; thus, a graph is represented by the superior half of its adjacency matrix
Then I define a proposition edge stating that there is an edge between two vertices of the graph (Vnth is, as the name states, nth adapted for BVectors; I include it in graphs-coq-club.v):
Inductive edge : forall n, (graph n) -> nat -> nat -> Prop :=
| edge_last_r : forall n (g : graph n) (v : Bvector n) m (Hm : m < n),
Is_true (Vnth n m v Hm) -> edge (S n) (gcons n v g) n m
| edge_last_l : forall n (g : graph n) (v : Bvector n) m (Hm : m < n),
Is_true (Vnth n m v Hm) -> edge (S n) (gcons n v g) m n
| edge_inside : forall n x y (g:graph n) (v : Bvector n),
edge n g x y -> edge (S n) (gcons n v g) x y.
Until here, everything is in order and I get on to proving basic facts about edges: there are no loops, edges are symmetric ... This proofs carry on well except that I sometimes have to use simple inversion instead of inversion, which seems to forget that the graph used in gcons is given unambiguously by gcons even when applying edge_last_{r,l}. Is there a not-inria-employee accessible reason for this ? This problem seems to be version-dependent: it seems to only show up in 8.1, as opposed to 8.0. Is there any change to inversion in 8.1 that can explain this ? (I'm using 8.1)
Then I want to define a function for deciding whether an edge is in a graph or not. I'm defining:
Definition edge_dec : forall n (g:graph n) x y, {edge n g x y}+{~edge n g x y}
I get to the case where I have y=n, g=(gcons n l g) and (Vnth n x l _ = false), and I want to prove that there is no edge.
The goal is:
x : nat
n : nat
l : Bvector n
g : graph n
Hxn : x < n
n0 : ~ edge n g x n
e : Vnth n x l Hxn = false
He : edge (S n) (gcons n l g) x n
______________________________________(1/4)
False
When I (simple) invert He, I get rid of the case edge_last_r with omega, but for the next case I have the following goal:
x : nat
n : nat
l : Bvector n
g : graph n
Hxn : x < n
n0 : ~ edge n g x n
g0 : graph n
v : Bvector n
H1 : existT (fun n : nat => graph n) (S n) (gcons n v g0) =
existT (fun n : nat => graph n) (S n) (gcons n l g)
Hm : x < n
Hg_g0 : existT (fun n : nat => graph n) n g0 =
Htrue : Is_true (Vnth n x v Hm)
>>>>> Hvl : existT (fun n : nat => Bvector n) n v =
>>>>> existT (fun n : nat => Bvector n) n l
>>>>> e0 : Vnth n x v Hxn = true
______________________________________(1/6)
False
given Hvl, e0 and e seem clearly in contradiction.
Yet, dependent rewrite Hvl doesn't work on any of them : it "Cannot find a well-typed generalization of the goal that makes the proof progress". How comes ? Why can't it rewrite e0 as Vnth n x l Hxn = true ? Moreover, this error message doesn't seem to show up in http://coq.inria.fr/V8.1/refman/index.html. Am I stuck for a deep reason, or is there a way around that problem? I attach a file with more context for those wanting to see the actual proofs (or non proofs, given this problem).
Friendly
Florent
Require Import List.
Require Import Bool.
Require Import Peano_dec.
Require Import Compare_dec.
Require Import Even.
Require Import Bvector.
Require Import Arith.
Require Import Omega.
| gnil : graph 0
Definition Vnth : forall (n m : nat) (v : Bvector n), m < n -> bool.
Proof.
intros n m v.
generalize m.
clear m.
induction v.
intros.
elim (lt_n_O m H).
destruct m.
intros _.
exact a.
intro Hmn. apply lt_S_n in Hmn.
exact (IHv m Hmn).
Defined.
(* Vnth doesn't depend on its proof argument *)
Lemma Vnth_ind_proof_lt : forall (n m : nat) (v : Bvector n) (H1 H2 : m<n),
Vnth n m v H1 = Vnth n m v H2.
Proof.
intros n m v; generalize m; clear m.
induction v; intros.
inversion H1.
destruct m.
simpl; reflexivity.
simpl. apply IHv.
Qed.
(* Definition of an edge; vertices are numbered from 0 to n-1 *)
(gcons n v g) n m
(gcons n v g) m n
g) x y.
(* there are no loops*)
Hypothesis edge_irrefl : forall n (g: graph n) x, ~edge n g x x.
(* there are only edges between vertices that are in the graph *)
Hypothesis edge_bounded : forall n (g:graph n) x y, edge n g x y -> x < n /\
y < n.
(* edge is symmetrical *)
Lemma edge_sym_last_l : forall n (g: graph (S n)) y, edge (S n) g n y ->
edge (S n) g y n.
Proof.
intros n g y H; simple inversion H; simpl in *.
(* the «simple» seems indispensable to get g "=" g0 *)
subst n0. subst y. intro Hv. dependent rewrite <- H2.
exact (edge_last_l n g0 v m Hm Hv).
apply False_ind; omega.
intro Hedge; apply False_ind; injection H1; intro Hn0; subst n0 y0 x;
generalize (edge_bounded n g0 n y Hedge); omega.
Qed.
Hypothesis edge_sym_last_r : forall n (g: graph (S n)) y, edge (S n) g y n
-> edge (S n) g n y.
Hypothesis edge_sym : forall n (g: graph n) x y, edge n g x y -> edge n g y x.
(* deciding edge... or rather, getting stuck with (simple) inversion *)
Definition edge_dec : forall (n x y:nat) (g:graph n), {edge n g x y}+{~edge n
g x y}.
Proof.
induction g.
(* empty graph *)
right; intro H; inversion H.
destruct IHg as [e | Hnegxy].
(* recursive case *)
left; apply edge_inside; trivial.
(* negative case, now we have to see why ... *)
destruct (lt_eq_lt_dec x n) as [[Hxn|Hxn]|Hxn].
destruct (lt_eq_lt_dec y n) as [[Hyn|Hyn]|Hyn].
(* the edge would be inside but is not *)
right; intro He. inversion He.
omega.
omega.
elim Hnegxy; dependent rewrite <- H2; trivial.
(* y=n, troubles start *)
subst. clear Hnegxy.
destruct (sumbool_of_bool (Vnth n x l Hxn)).
(* the edge is here, easy *)
left; apply edge_last_l with (Hm := Hxn).
rewrite e; simpl; tauto.
(* the edge doesn't exist, we have to invert... *)
right. intro He. simple inversion He.
intros; omega.
subst. clear H0.
injection H1.
intros Hg_g0 Hvl.
intros Htrue.
destruct (sumbool_of_bool (Vnth n x v Hm)) .
rewrite (Vnth_ind_proof_lt n x v Hm Hxn) in e0.
Admitted. (* dependent rewrite Hvl in e0. échoue, et moi avec*)(**
Pour edge, dans un graphe de taille n, les sommets sont numérotés de
* 0 à n-1 *)
(* Proofs for the lemmas which were admitted : *)
Lemma edge_irrefl_l : forall n (g: graph n) x, ~edge n g x x.
Proof.
induction g.
intros x H; inversion H.
omega.
omega.
elim (IHg x); dependent rewrite <- H3; trivial.
Qed.
(* il n'y a d'arete qu'entre des sommets du graphe*)
Lemma edge_bounded_l : forall n (g:graph n) x y, edge n g x y -> x < n /\ y <
n.
Proof.
induction g.
intros x y He; inversion He.
omega.
omega.
generalize H4; dependent rewrite H2; simpl in |- *; intros H5.
generalize (IHg x y H5); omega.
Qed.
(* la relation edge est symetrique*)
Lemma edge_sym_last_l_l : forall n (g: graph (S n)) y, edge (S n) g n y ->
edge (S n) g y n.
Proof.
Qed.
Lemma edge_sym_last_r_l : forall n (g: graph (S n)) y, edge (S n) g y n ->
edge (S n) g n y.
Proof.
simpl. exact (edge_last_r n g0 v m Hm Hv).
intro Hedge; apply False_ind; injection H1; intro Hn0; subst n0 y0 x.
generalize (edge_bounded n g0 y n Hedge); omega.
Qed.
Lemma edge_sym_l : forall n (g: graph n) x y, edge n g x y -> edge n g y x.
Proof.
induction g.
intros x y H; inversion H.
subst; apply edge_sym_last_l_l; trivial.
subst; apply edge_sym_last_r_l; trivial.
apply edge_inside.
apply IHg; dependent rewrite <- H3; trivial.
Qed.
- [Coq-Club] inversion, simple inversion and dependent rewrite, Florent Becker
- Re: [Coq-Club] inversion, simple inversion and dependent rewrite, Nicolas Magaud
