coq-club - Re: [Coq-Club] Modules and visibility
chronological Thread
  • From: Andrew McCreight <andrew.mccreight AT yale.edu>
  • To: Guillaume Melquiond <guillaume.melquiond AT ens-lyon.fr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Modules and visibility
  • Date: Thu, 3 May 2007 08:46:48 -0400 (EDT)
Hi,
I think something like:
Module B : A with Definition T := nat.
will work. I don't remember the precise syntax, but this basically specializes the module type for the case where T is nat. This will expose the definition of T without exposing the rest.
-Andrew
On Thu, 3 May 2007, Guillaume Melquiond wrote:
Hi,
I am trying to use the module system with Coq 8.1 and I don't seem to
get a sensible behavior. The following example defines an interface A (a
module type) and an implementation B (a module) for this interface. The
function g is an implementation detail (not in A, only in B) and it
should be hidden to the user of module B. So I am typing the following
script:
       Module Type A.
         Parameter T : Type.
         Parameter f : T -> T.
       End A.
       Module B : A.
         Definition g := S.
         Definition f := fun x : T => x.
       End B.
       Import B.
       Print T.
       Check (f 0).
Unfortunately, B can not be used at all, as Coq considers the type
definition T to be opaque. For the last two lines, Coq prints:
       *** [ T : Type ]
       Error: The term "0" has type "nat" while it is expected to have type
"T"
The only way I have found so that I can use B is to replace the type
specification "B : A" with "B <: A". Coq now prints:
       T = nat
            : Set
       f 0
            : nat
Unfortunately, the implementation detail g now pollutes the global
scope. The documentation does not describe other ways of defining a
module of a given type. How can I get a usable module (T not opaque)
without leaking any implementations details (e.g. hundreds of
intermediate lemmas)?
Best regards,
Guillaume
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
         http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
