coq-club - Re: [Coq-Club] Goal ordering in Ltac
chronological Thread
  • From: "Brian E. Aydemir" <baydemir AT cis.upenn.edu>
  • To: Sean Wilson <sean.wilson AT ed.ac.uk>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Goal ordering in Ltac
  • Date: Tue, 8 May 2007 15:32:18 -0400
On May 8, 2007, at 2:45 PM, Sean Wilson wrote:
Also, are there any ways in which Ltac tactics can return results (like lists or numbers) for other tactics to use? For instance, can I write a tactic that returns a list of all assumptions in the hypothesis with type nat which can be passed as input to another tactic which calls "clear" for each assumption found?
I believe the general answer is "yes". For your particular example, you can try the following:
Require Import List.
Ltac gather_nat_hyps :=
  let rec gather acc :=
    match goal with
    | H : nat |- _ =>
        match acc with
        (* This first case is important as it
           allows us to avoid an infinite loop.
           See also: how "match goal with" works.
        | context [H] => fail 1
        | _ => gather (H :: acc)
        end
    | _ => acc
    end
  in
    gather (@nil nat).
Ltac clear_hyps Hs :=
  match Hs with
  | nil => idtac
  | cons ?H ?Hs => try clear H; clear_hyps Hs
  end.
Lemma test : forall (a b c n m : nat), n = m.
Proof.
  intros.
  clear_hyps gather_nat_hyps.
I believe gather_nat_hyps has a running time quadratic in the size of the current context, but together, these tactics seem to do what you asked. (Maybe there is a better way to do a fold over the current context?) In any event, I've found Chapter 9 of the reference manual (The tactic language) to be a useful reference.
Hope that helps,
Brian
