coq-club - [Coq-Club] Usually solution for Coq's rewriting
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Usually solution for Coq's rewriting
  • Date: Thu, 24 May 2007 15:04:38 +0200 (CEST)
  • Importance: Normal
Hi,
Can somebody tell me what is a usually solution for situation when Coq
automatically rewrite variable, but I need to rewrite these variable after
that, with some hypotheses introduced in environment before using opening
proof mode.
For example:
Coq < Section Proba.
Coq < Parameter x y : nat.
x is assumed
y is assumed
Coq < Goal exists y, x=y.
1 subgoal
   exists y0 : nat, x = y0
So, I like to have hypotheses for rewriting but I cannot using name y0
because than Coq will rewrite y in some another name. Introducing new
hypotheses using tactics after Coq's rewriting don't look so elegant.
Thank you very much,
Marko Malikoviæ
