- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Difference between exists and sigT
- Date: Mon, 4 Jun 2007 20:05:39 -0700 (PDT)
Although I've run across these two things before in my learning Coq, I still
don't really know what the difference is. The main issue that's prompting
my question is that in a particular library I have a bijective Map from one
setoid to another. I figured it'd be easy to create the inverse map --
wrong! Because bijectivity is defined with "exists", I can't elim it to
"instantiate" the preimages to define the inverse map. The error Coq gives
is:
"User error: Cannot find the elimination combinator ex_rect
The elimination of the inductive definition ex_rect on sort Type is not
allowed"
I have the feeling that if the maps were defined using sigT instead of
exists, I might be able to do what I want. Is that correct?
View this message in context:
http://www.nabble.com/Difference-between-exists-and-sigT-tf3869234.html#a10962330
Sent from the Coq mailing list archive at Nabble.com.
- [Coq-Club] Difference between exists and sigT, rk1
