- From: Arnaud Spiwack <aspiwack AT lix.polytechnique.fr>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Tactics for goals containing "exists"
- Date: Fri, 08 Jun 2007 21:26:18 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=beta; h=received:message-id:date:from:user-agent:mime-version:to:subject:references:in-reply-to:content-type:content-transfer-encoding:sender; b=UU2a+BB9CZEuLIjJul6j83GP3ui7olfju+ak0VCaly8a2mj1rvsLahWJiuGDn0fuGF76ds3MKVQ/c956hfChfQvVC+SRMuB2KNE7bNthm4g0r052Cob8PmLOv47Ns2luBxmW85NEu/VL2jyQNjJeOeEr7mVbWKvTYOt/uYQeY8o=
Well, this is a rather typical use of the "esplit" tactic. It is a variation of "eapply" for inductive types with a single constructor type. It simply destruct the constructor in the goal generating metavariables where dependencies are needed.
A bit of action :
Require Import List.
Axiom A : Set.
Goal forall (h:A) (t:list A) (o:list A), exists f : list A, f ++ o = h::t ++o.
intros.
esplit.
change (h::t++o) with ((h::t)++o).
reflexivity.
Qed.
As you can see while running the proof, unification is done at the time of the "reflexivity". I haven't figured a way to go around the "change" though, since "h::t++o" is in normal form where "(h::t)++o" is not. Coq unification is very first order.
Arnaud Spiwack
Sean Wilson a écrit :
Hi,
I'm working with goals containing existential quantifiers like the following:
h : A
t : list A
o : list A
______________________________________(1/1)
exists f : list A, f ++ o = h :: t ++ o
To progress, I must call "exists h::t", which you can work out by unification of the two sides of the equality. Does Coq have any way of inferring this and solving the goal automatically? Also, are there any other tactics besides "exists" that let me manipulate goals like this in useful ways?
Regards,
Sean
Bug reports: http://coq.inria.fr/bin/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Tactics for goals containing "exists", Sean Wilson
- Re: [Coq-Club] Tactics for goals containing "exists", Arnaud Spiwack
- Re: [Coq-Club] Tactics for goals containing "exists", Andrew McCreight
