- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] setoid_replace with parameteric relations.
- Date: Tue, 19 Jun 2007 10:41:01 -0400 (EDT)
I've declared a setoid relation:
Relation (ms,ms_eq);
where ms: MetricSpace -> Type
and ms_eq: forall m : MetricSpace, ms m -> ms m -> Prop
I haven't been able to get setoid_rewrite to work on instances of this.
Even the most simple case:
x : ms R
y : ms R
______________________________________(1/2)
@ms_eq R x y
setoid_replace x with y.
generates the goal:
______________________________________(2/3)
@eq (ms R) y x
instead of @ms_eq R y x.
I've tried
setoid_replace x with y using relation ms_eq.
which gives the error message: ``User error: Not a proposition or a type''
and I've tried
setoid_replace x with y using relation (@ms_eq R).
which gives the error message: ``User error: @ms_eq R is not a registered relation.''
How do I use setoid_rewrite with parametric relations?
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] setoid_replace with parameteric relations., roconnor
