- From: Jean-Christophe Filliatre <filliatr AT lri.fr>
- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Postdoc Position: Functional Interpretation of C Functions
- Date: Fri, 29 Jun 2007 09:59:10 +0200
At the INRIA Futurs (Orsay, France), a postdoc position for one year
is available in the ProVal project, devoted to
Starting date of this Postdoc position: September 2007
Context:
The ProVal project is developing the tool Caduceus for the
formal verification of behavioral properties of C programs at the
source level (http://caduceus.lri.fr/). It is based on a classical
Hoare Logic framework where programs are annotated with pre- and
postconditions and loop invariants.
Description of the postdoc activity:
To be modular, Hoare Logic requires each function to be given a
postcondition describing the computation it performs. Most of the
time, this postcondition appears to be an abstraction of the
function's code. In some cases, however, the postcondition is simply
rephrasing the code, which constitutes both a duplication of the
code and a useless proof search.
The aim of this work is to design and implement a method to
automatically associate a postcondition to some particular C
functions (to be identified), as a functional interpretation of
their codes. We will start with simple functions performing only
tests and computations on local variables. Then we will extend it to
side-effects on global variables. Finally, we will study the case of
loops where the functional interpretation could be expressed as
inductive relations.
This work will be part of the RNTL project CAT (C Analysis Toolbox)
and its results will be directly applied to industrial critical code.
Required knowledge and competences:
- notions of formal methods (especially Hoare Logic)
- programming skills with the languages C and Objective Caml
For further information about this position please contact
Jean-Christophe.Filliatre at lri.fr
- [Coq-Club] Postdoc Position: Functional Interpretation of C Functions, Jean-Christophe Filliatre
