- To: Param Jyothi Reddy <paramr AT gmail.com>
- Cc: types AT cis.upenn.edu, Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Proof term for proof by exhaustion
- Date: Wed, 11 Jul 2007 02:14:24 -0400 (EDT)
On Tue, 10 Jul 2007, Param Jyothi Reddy wrote:
Hi,
Lets define vector in usual way with constructors:
nil : Vector T 0
cons : Vector T n -> T -> Vector T (S n)
along with its inductive elimination rule. Let BD be type of Binary
Digits (enumeration with elements 0 and 1).
Also lets say i have proofs of some predicate P for all elements of
Vector's over BD of length 2, i.e.
p_0 : P(00), p_1 : P(01), p_2 : P(10), p_3 : P(11), where bd is cons
(cons nil d) b.
using these How will the proof term for
(forall v : Vector BD (S S 0) ). P(v) look like?
Here is one way to prove it, but I use the lemmas VSn_eq and V0_eq, so it may not answer the question you are asking.
Require Import Bvector.
Section V.
Variable P : vector bool 2 -> Prop.
Hypothesis P0 : P (Vcons _ false _ (Vcons _ false _ (Vnil _))).
Hypothesis P1 : P (Vcons _ false _ (Vcons _ true _ (Vnil _))).
Hypothesis P2 : P (Vcons _ true _ (Vcons _ false _ (Vnil _))).
Hypothesis P3 : P (Vcons _ true _ (Vcons _ true _ (Vnil _))).
Lemma HP : forall (v:vector bool 2), P v.
Proof.
intros v.
rewrite VSn_eq.
generalize (Vhead bool 1 v) (Vtail bool 1 v).
clear v.
intros b0 v0.
rewrite (VSn_eq _ _ v0).
rewrite (V0_eq _ (Vtail bool 0 v0)).
generalize (Vhead bool 0 v0).
clear v0.
intros b1.
destruct b0; destruct b1; assumption.
Qed.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] Proof term for proof by exhaustion, Param Jyothi Reddy
- Re: [Coq-Club] Proof term for proof by exhaustion,
Benjamin Werner
- Re: [Coq-Club] Proof term for proof by exhaustion, Param Jyothi Reddy
- Re: [Coq-Club] Proof term for proof by exhaustion, roconnor
Benjamin Werner
