coq-club - Re: [Coq-Club] Understanding sort polymorphism
chronological Thread
  • To: Brian Aydemir <baydemir AT cis.upenn.edu>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Understanding sort polymorphism
  • Date: Thu, 12 Jul 2007 12:49:42 -0700
My understanding is that sort polymorphism is not a genuine feature of CIC, or whatever the specific logic behind Coq is called these days. Rather, this feature is more like a "macro system" added on top as a convenience. Sometimes, the type checker is able to notice that you are using a definition in a way that can be made more general, and it creates a new definition of the associated inductive type with a different sort. You as the user don't need to worry about this definition duplication, as the system manages it for you, giving the illusion of "real" polymorphism.
Once a "sort polymorphic" identifier is hidden inside a definition, later users don't see it, and so the system doesn't apply the extra-redefinition trick in those cases.
I don't know how sort polymorphism is implemented; it might be in a way that makes it look like the polymorphism is "real." I think the metatheory is trickier with "real" sort polymorphism, though, and it's easiest to treat this as a smart macro system.
Brian Aydemir wrote:
Hi everyone,
I have a question about sort polymorphism in Coq 8.1. Consider the following example.
Parameter bind : Set.
Definition env := list.
Print env.         (* env        : Type -> Type *)
Check (env bind).  (* env bind   : Type *)
Check (list bind). (* list bind  : Set *)
My question: why are (env bind) and (list bind) assigned different sorts? The two are convertible with each other. It seems strange that "wrapping" list behind a Definition would all of a sudden change the sorts that are assigned to entities. What exactly is going on here?
