coq-club - Re: [Coq-Club] Search trees
chronological Thread
  • To: Marko Malikovi� <marko AT ffri.hr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Search trees
  • Date: Mon, 16 Jul 2007 14:53:37 -0700
Perhaps someone else understands your explanation or example, but I don't. It would probably be better to give "pseudo-Coq" code; that is, make it look as much like a valid Coq session as possible, but feeling free to cut corners where necessary (like when something won't really type-check).
Marko Malikoviæ wrote:
Is it possible in Coq to define a search tree with nodes labeled with
predicates? By default, values in the nodes should be Set, Prop or Type.
But, I need to label nodes with (unique) predicates, for example:
Predicate A 3 4
Predicate A 3 4   Predicate C 2 6
Predicate C 8 2   Predicate B 5 4   Predicate E 3 4   Predicate D 3 7
and so on.
