coq-club - [Coq-Club] prod_f_SO and f(0)
chronological Thread
Hello,
I recently needed a function to compute the product of n values. I then discovered the function prod_f_SO ((nat->R)-> nat-> R) that, given a
function f:nat-> R, computes f(1)*...*f(n). Note the f(0) is unused. It multiplies the values of f(i) from i from 1 to n...
This is surprising as f is defined on all N, and it is inconsistent with the corresponding adding function sum_f_R0 that computes f(0)+f(1)+...+f(n).
It is not very elegant, but the most surprising is that the lemmas on prod_f_S0 seem to assume that f(0) is needed! For example (lemma prod_SO_pos), for the product to be nonnegative, I need all the values including the unused f(0) to be nonnegative.
OK, I was able to prove the same lemma without f(0) needing to be nonnegative, but it may be a good idea to change something (either the definition or the lemmas) to be coherent.
Personnally, I would vote on the definition to be changed for consistency with sum_f_R0.
Regards,
Sylvie Boldo
Sylvie Boldo, projet ProVal, INRIA Futurs, PCRI
