coq-club - [Coq-Club] Rewrite rules from functions
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] Rewrite rules from functions
  • Date: Tue, 21 Aug 2007 16:18:17 +0100
  • Organization: School of Informatics, The University of Edinburgh
Hi,
I'm trying to write some automatic rewriting tactics and was wondering if Coq
already has a certain feature already.
Given the usual definition of app:
fun A : Type =>
fix app (l m : list A) {struct l} : list A :=
  match l with
  | nil => m
  | a :: l1 => a :: app l1 m
  end
From this definition, we can directly read off two rewrite rules it implies:
forall m, app nil m = m
forall a l1 m, app (a::l1) m = a::app l1 m
With these, we can reduce terms containing app using rewriting without having
to use the "simpl" tactic. The important points for me is that I want to be
able to apply reductions one step at a time (in case it is simplified too
much) and I want access to these rules in both directions. My question is,
does Coq have a feature that allows me to extract these rewrite rules from
functions automatically?
Also, is there another (easier) way I can get access to the right-to-left
versions of these rewrites? I think there's a way using tactics to perform
only one reduction at a time but I don't know how they could be applied in
reverse.
By experimenting with tactics, I've found that it's not hard to produce these
rewrite rules by starting with the lemma "app x y = app x y", unfolding the
first app, doing case analysis on x and y, then calling various other tactics
(e.g. to clear up let/in constructs, simplify branches) and folding up app
definitions to finish up with several (trivial) subgoals, where each goal
statement is a rewrite rule I need. Doing this, and some hacking in OCaml, I
can see how one could do it, but I wanted to check if such a feature existed
already.
Thanks,
Sean
