- To: Fr�d�ric Besson <fbesson AT irisa.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Match and number of subgoal
- Date: Fri, 24 Aug 2007 18:27:57 +0200 (CEST)
- Importance: Normal
Dear Frédéric,
thank you, but anyway I know which tactic is applied to which subgoal (for
example, I have expression1, expression2, ... already in subgoals). I need
conversely think: number of subgoal for every application of tactics
tactic1, tactic2,... etc. It is because I will after tactic1, tactic2,...
apply another tactics to every subgoal, but which is another tactics it
depends on subgoal number. Fpr example:
Ltac example :> match goal with
| [ |- expression1 ] => tactic1;apply ident with No. of subgoal
| [ |- expression2 ] => tactic2;apply ident with No. of subgoal
| [ |- expression3 ] => tactic3;apply ident with No. of subgoal
| [ |- expressionN ] => tacticN;apply ident with No. of subgoal
| [ |- _ ] => idtac
end.
Greetings,
Marko Malikoviæ
Frédéric Besson reèe:
> On 24 août 07, at 14:46, Marko Maliković wrote:
>> if I have Ltac like this:
>> | [ |- _ ] => idtac
>> end.
>> and I apply this matching on all before generated subgoals
>> (with ;example
>> tactical), how I can know which tactic is applied on which subgoal.
>> Exactly I need ordinal number of subgoal.
>> Concrete, if after ";example", tactic3 is applied on i-th subgoal
>> than I
>> need what number i is.
> Maybe you could tag subgoals with a string.
> (It does not provide the subgoal number but each subgoal is annotated
> with the tactic that applied to it.)
> Require Import String. Open Scope string_scope.
> Ltac example : let tag := fresh "tag" in
> match goal with
> | [ |- expression1 ] => tactic1 ; set (tag := "tactic1")
> | [ |- expression2 ] => tactic2 ; set (tag := "tactic2")
> | [ |- expressionN ] => tacticN ;set (tag := "tacticN")
> | [ |- _ ] => idtac
> end.
> Regards,
> Frédéric Besson
- [Coq-Club] Match and number of subgoal, Marko Malikoviæ
- Re: [Coq-Club] Match and number of subgoal,
Frédéric Besson
- Re: [Coq-Club] Match and number of subgoal, Marko Malikoviæ
Frédéric Besson
