coq-club - Re: [Coq-Club] Basic question on navigating inductive proofs
chronological Thread
  • To: Benjamin Pierce <bcpierce AT cis.upenn.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Basic question on navigating inductive proofs
  • Date: Fri, 31 Aug 2007 09:19:50 -0700
Benjamin Pierce wrote:
When writing or reading big inductive proofs in Coq, I find it's quite difficult to keep track of which case of the induction one is in at any given moment: The proof script doesn't signal explicitly when one case is finished and we are moving on to the next.
What do people do about this?
My opinion is that, in any proof complicated enough to make this a problem, you should prove each inductive case as its own lemma. Then, add each lemma as an 'auto' hint, possibly to a database just for the theorem that you want to prove. Now the final proof is just 'induction something; eauto with MyDatabase.'. The end result should be more readable than anything just using a single proof script, as you have the setting of each inductive case spelled out explicitly in your code. (You can even make the proof easier to understand by dropping hypotheses that aren't needed on a per-case basis.)
If you're just trying to prove a theorem without being concerned about leaving an artifact that others can read to "understand" the proof, then best yet is if you just automate the whole thing inside a single proof script by adding plenty of hints ahead of time and skipping the lemmas!
