- From: David Pichardie <david.pichardie AT irisa.fr>
- To: Marko Maliković <marko AT ffri.hr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Recursive function with increasing arguments
- Date: Fri, 14 Sep 2007 11:37:11 +0200
Dear Marko,
Here is a solution using the new Function feature.
I have rewriten your function using eq_nat_dec instead of pattern- matching because Function is not very efficient
with too big pattern matching.
Require Import List.
Definition list_A :=
(2 :: 2 :: 3 :: 3 :: nil) ::
(4 :: 4 :: 2 :: 1 :: nil) ::
(1 :: 1 :: 1 :: 2 :: nil) ::
(3 :: 2 :: 4 :: 5 :: nil) ::
(5 :: 5 :: 4 :: 1 :: nil) ::
nil.
Require Import Recdef.
Definition mes (x:nat) : nat := 10-x.
Require Import Arith.
Require Import Omega.
Function problem (x y:nat) {measure mes x} : Prop :=
if eq_nat_dec (nth y (nth x list_A nil) 0) 5 then
if eq_nat_dec (nth (y+1) (nth (x+1) list_A nil) 0 ) 1 then True
else
if eq_nat_dec (nth (y+1) (nth (x+1) list_A nil) 0 ) 2 then
if eq_nat_dec x 9 then False
else if eq_nat_dec y 9 then False
else problem (S x) (S y)
else False
else False.
intros; unfold mes; subst.
destruct (le_lt_dec x 9).
(* case x<= 9 *)
omega.
(* case x> 9 : hypothesis anaonymous 1 is absurd *)
absurd (0=2).
omega.
rewrite <- anonymous1.
rewrite nth_overflow; auto.
rewrite nth_overflow; simpl; try omega.
Qed.
I use a measure function. I have then to prove that recursive call are decresing wrt this measure.
Essentially I must prove this subgoal :
anonymous1 : nth (y + 1) (nth (x + 1) list_A nil) 0 = 2
anonymous2 : x <> 9
10 - S x < 10 - x
Hope this helps.
David.
Le 14 sept. 07 à 11:00, Marko Maliković a écrit :
Dear Coq developers and users,
Have somebody idea how to build recursive function when all arguments are
increasing, but without using CoInductive types (just inductive)?
For example, on the bottom of this mail is recursive definition of
function "problem". Normally, it is ill-formed because x and y are
increasing (don't look too much in data's of example because this example
is fanciful).
Anyway, this function will always stop because of:
match x' with
10 => False
match y' with
10 => False
But Coq don't know that function will always stop.
One way is to embed some decreasing argument i and use {struct i} but then
I must to have i like argument in "problem x y i" and it is not so nice
(although I can ignore this argument i).
My second idea was to use "pred" (predecessor) but it is a function and it
is not well formed constructor.
Some ideas (I repeat: without CoInductive types).
Thank you very much,
Marko Maliković
Here is example:
nil.
Fixpoint problem (x y:nat) {struct x} : Prop :=
match nth y (nth x list_A nil) 0 with
5 => match nth (y+1) (nth (x+1) list_A nil) 0 with
1 => True
| 2 => match x+2 with
S x' => match y+2 with
S y' => match x' with
10 => False
| _ => match y' with
10 => False
| _ => problem x' y'
end
end
| _ => False
end
| _ => False
end
| _ => False
end
| _ => False
end.
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Recursive function with increasing arguments, Marko Malikoviæ
- Re: [Coq-Club] Recursive function with increasing arguments, David Pichardie
- <Possible follow-ups>
- Re: [Coq-Club] Recursive function with increasing arguments, Venanzio Capretta
