Re: [Coq-Club] Infinite loop under enumerated inductive type when using command Function
chronological Thread
- To: Marko Malikovi� <marko AT ffri.hr>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Infinite loop under enumerated inductive type when using command Function
- Date: Mon, 17 Sep 2007 03:08:02 -0400 (EDT)
On Mon, 17 Sep 2007, Marko Malikovi? wrote:
But, this analogous case does not work well:
Inductive for_list : Set := a | b | c | d.
Require Import List.
Definition list_B :=
(a :: b :: a :: a :: nil) ::
(c :: a :: a :: b :: nil) ::
(a :: c :: a :: a :: nil) ::
(c :: b :: c :: c :: nil) ::
(a :: c :: b :: a :: nil) ::
nil.
Require Import Recdef.
Definition mes (x:nat) : nat := 3-x.
Require Import Arith.
Require Import Omega.
Lemma eq_list_B : forall x y:for_list, {x=y}+{~x=y}.
decide equality.
Qed.
Replace Qed. with Defined.
Function problem (x y:nat) {measure mes x} : Prop :=
if eq_list_B (nth y (nth x list_B nil) d) a then
if eq_list_B (nth (y+1) (nth (x+1) list_B nil) d) c then True
else
if eq_list_B (nth (y+1) (nth (x+1) list_B nil) d) a then
if eq_nat_dec x 3 then False
else if eq_nat_dec y 3 then False
else problem (S x) (S y)
else False
else False.
intros; unfold mes; subst.
destruct (le_lt_dec x 3).
omega.
absurd (d=a).
discriminate.
rewrite <- anonymous1.
rewrite nth_overflow; auto.
rewrite nth_overflow; simpl; try omega.
Qed.
Here also replace Qed. with Defined.
Goal problem 1 1.
compute.
get into infinite loop (I repeat: I just think it is infinite loop).
This isn't a infinite loop, rather Qed makes the eq_list_B symbol opaque, which means the definition cannot be unfolded. Without being able to unfold the defintion of eq_list_B, the resulting normal form of problem 1 1 is very large.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] Infinite loop under enumerated inductive type when using command Function, Marko Malikoviæ
- Re: [Coq-Club] Infinite loop under enumerated inductive type when using command Function, roconnor
- Re: [Coq-Club] Infinite loop under enumerated inductive type when using command Function, Pierre Courtieu
