- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Behavior of (auto)rewrite with existential variables
- Date: Tue, 18 Sep 2007 10:38:50 -0400
Hi everyone,
The following toy example illustrates the interaction of the rewrite and autorewrite tactics with existential variables. The behavior I'm seeing (in Coq 8.1pl1) surprises me, so I am hoping that someone here can explain exactly what is happening.
Require Import List.
(* Pick a theorem to use as a rewrite rule. *)
Check app_nil_end. (* forall (A : Type) (l : list A), l = l ++ nil *)
Hint Rewrite <- app_nil_end : db.
(* Use that theorem in a silly proof now.
The statement itself is unimportant. *)
Lemma test : exists L : list nat, ~ In 0 L -> True.
Proof.
(* Introduce an existential variable.
This is a key point in this example. *)
econstructor.
intros H.
(* The goal now looks like the following:
H : ~ In 0 ?3
True
(* The following loops forever it seems: autorewrite with db in H.
Let's try something simpler. *)
rewrite <- app_nil_end in H.
H : ~ In 0 ?35484
True
Admitted.
It seems that (auto)rewrite is succeeding even when the term being rewritten is an existential variable. Is this the intended behavior of these tactics or is this a bug? If the behavior is intended, how should I make sense of it?
Also, is there a way to prevent (auto)rewrite from rewriting a term that is an existential variable? In the larger example where I first encountered this behavior, autorewrite is being invoked via a Hint Extern in order to simplify goals. This in turn helps (e)auto solve many, uninteresting goals. Thus, I do not want to remove the Hint Externs. Is my only other choice to be more careful where eauto is used?
Thanks,
Brian
- [Coq-Club] Behavior of (auto)rewrite with existential variables, Brian Aydemir
