- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] ask for help
- Date: Mon, 15 Oct 2007 09:08:36 +0800
Dear Instructors
ask for help
1,how to use the tactic destruct.
2,if I have defined some Definitions such as
Definition A1:=a=b.
Defintion A2:= c->d.
and I want to use the Definition A1 or A2 when proving the lemma.
for example Lemma b=c->(a->d).
what tactic I should use.
3 if I face the situation there are the parameters in the statements such as
forall x y:nat f x -> g y .and also there are the parameters in goal maybe
Lemma
forall x y:nat p x-> q y . which means they are acturally the same
parameters,but
in goals the parameters changed into x0 y0,but in statements parameters are x
y,
how to use tactic to solve this?
4 if there are H0 a->b->c->d->e in the statement and there's a Deinition
AB:=a=h.Defintion ABC:=h->f.I want to use only a to get h through AB,and
then I
can get f from h through ABC .so how to make a alone as H. Amd how to use
tactic
to get h from a through AB, then get f from ABC.
thanks looking forward your E-mails!
Judy.
- [Coq-Club] ask for help,
- Re: [Coq-Club] ask for help, Yves Bertot
