- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Selectively opening modules
- Date: Wed, 17 Oct 2007 06:42:47 -0400
Hi,
I have a module that defines several names, and I would like to make just a subset of them available as unqualified identifiers in some other scope. From the documentation, I couldn't see a way to do this directly, but it seemed that defining an abbreviation for each one should be a reasonable workaround.
Module Foo.
Definition bar (x:nat) := x < 15.
End Foo.
Notation bar := Foo.bar.
However, this doesn't seem to work:
Check (bar 4).
(* This prints
Foo.bar 4
: Prop
instead of:
bar 4
: Prop *)
Is this a bug in the printing function?
Is there a better way to achieve the effect I'm after?
Thanks!
- Benjamin
- [Coq-Club] Selectively opening modules, Benjamin Pierce
- Re: [Coq-Club] Selectively opening modules, Guillaume Melquiond
- Re: [Coq-Club] Selectively opening modules, Hugo Herbelin
