coq-club - Re: [Coq-Club] Two simple questions about coqdoc
chronological Thread
  • To: Brian Aydemir <baydemir AT cis.upenn.edu>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Two simple questions about coqdoc
  • Date: Thu, 25 Oct 2007 10:21:19 +0100
> > Try giving the --gallina (or -g for short) flag to coqdoc.  That
> > should do what you want here.
> Thanks for the quick reply. However, when I specify -g, definitions and
> fixpoints disappear along with the proofs.
Right, after some experimenting it turns out that coqdoc is thrown off
by the presence of non-Unix style line endings; when I run
  coqdoc -g Proofs.v --latex && latex Proofs.tex
all sorts of stuff is missing from the output, but then when I run
  dos2unix Proofs.v
and re-generate the .tex file, everything works as expected.
Running gallina *does* work without converting line endings first.
Thanks for the help,
Edsko
