- To: westand <westand AT seas.upenn.edu>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Problems compiling
- Date: Sun, 18 Nov 2007 09:46:07 +0000
On Sat, Nov 17, 2007 at 08:40:02AM -0800, westand wrote:
> I am trying to compile Coq 8.1. I run "./configure" and then "make world."
> The latter runs for about 15 minutes and then stumbles on the line:
> "COQMKTOP -o bin/coqtop.byte
> /usr/bin/ld: cannot find -lcurses
> collect2: ld returned 1 exit status
> Error while building custom runtime system
> make: *** [bin/coqtop.byte] Error 2"
> The "bin" directory does exist and I've gone inside the CONFIG file and
> changed tried compiling with "best_compiler" set to "opt" and "byte"
> with the same result. Any suggestions? Thanks,
It seems like your missing the ncurses library?
Edsko
- [Coq-Club] Problems compiling, westand
- Re: [Coq-Club] Problems compiling, Edsko de Vries
- Re: [Coq-Club] Problems compiling, Evgeny Makarov
