coq-club - Re: [Coq-Club] Automatic finding false hypothesis
chronological Thread
  • To: Marko Malikovi� <marko AT ffri.hr>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Automatic finding false hypothesis
  • Date: Sat, 24 Nov 2007 20:57:42 +0000
  • Organization: School of Informatics, The University of Edinburgh
On Saturday 24 November 2007 17:51:29 Marko Malikoviæ wrote:
> Thanks for Sean and Edsko for solutions,
> Anyway, Sean asked me for example and here is one very simple:
> Coq < Parameter valid_prop : Prop.
> valid_prop is assumed
> Coq < Require Import Omega.
> Coq < Goal 2>100 -> valid_prop.
> 1 subgoal
>    2 > 100 -> valid_prop
> Unnamed_thm < intro.
> 1 subgoal
>   H : 2 > 100
>    valid_prop
> Unnamed_thm < omega.
> Toplevel input, characters 0-5
> > omega.
> User error: Omega: Unrecognized atomic proposition: valid_prop
I've run into this problem too. It seems that if your conclusion is not a
statement about natural numbers, omega will just fail with the obscure
message that you see. You would expect it to look for a linear arithmetic
contradiction in the assumptions but it just fails. I used to do (absurd (0
<> 0);omega) to make omega find the contradiction but Edsko's snippet is more
efficient.
You could wrap up this trick in a tactic so omega works the way you expect it
to (i.e. solves the goal or finds a contradiction when it can):
Ltac omega2 := omega || (apply False_ind ; omega).
Regards,
Sean
