- From: Jean-Francois Monin <Jean-Francois.Monin AT imag.fr>
- To: Edsko de Vries <devriese AT cs.tcd.ie>, judy AT mail.ccnu.edu.cn
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] question
- Date: Tue, 27 Nov 2007 15:18:56 +0100
There is a big difference between AA1 end AA2 : only AA1
requires the decidability of equality (on nat).
Here is an elementary proof of a generalization of AA2.
Variable A : Set
Lemma AA2: forall (s s1 o o1 x x1:A),
(s<>s1)\/(o<>o1)\/(x<>x1) -> (s,o,x)<>(s1,o1,x1).
Proof.
intros s s1 o o1 x x1 [diff | [diff |diff ]] eq.
apply diff. change (fst (fst (s, o, x)) = s1). rewrite eq. reflexivity.
apply diff. change (snd (fst (s, o, x)) = o1). rewrite eq. reflexivity.
apply diff. change (snd (s, o, x) = x1). rewrite eq. reflexivity.
Qed.
An alternative to "change + rewrite + reflexivity" is to use injection
or even congruence, at once :
Proof.
intros s s1 o o1 x x1 [diff | [diff |diff ]] eq; congruence.
Qed.
JF
On Tue, Nov 27, 2007 at 10:57:41AM +0000, Edsko de Vries wrote:
> On Tue, Nov 27, 2007 at 02:20:03PM +0800,
> wrote:
> > Dear Professor:
> > how to prove:
> > Lemma AA1:forall (s s1 o o1 x x1:nat),
> > (s,o,x)<>(s1,o1,x1)->(s<>s1)\/(o<>o1)\/(x<>x1).
> One possibility is to use case analysis on whether s = s1, o = o1, x = x1:
> Proof.
> intros.
> elim (eq_nat_dec s s1) ; elim (eq_nat_dec o o1) ; elim (eq_nat_dec x x1)
> ; auto.
> intros.
> subst x1 o1 s1.
> apply False_ind ; apply H ; reflexivity.
> Qed.
> The 'auto' tactic solves the goal in all but one case (the case where s =
> s1, o
> = o1 and x = x1); in that case, there is a contradiction amongst the
> hypothesis
> and we can finish the proof using False_ind.
> The other lemma can probably be solved using a similar technique.
> Edsko
Jean-Francois Monin Univ. Joseph Fourier, GRENOBLE
VERIMAG - Centre Equation http://www-verimag.imag.fr/~monin/
2 avenue de Vignate tel (+33 | 0) 4 56 52 04 39
F-38610 GIERES fax (+33 | 0) 4 56 52 04 46
- [Coq-Club] question,
- Re: [Coq-Club] question,
Edsko de Vries
- Re: [Coq-Club] question, Jean-Francois Monin
Edsko de Vries
