- To: Wan Hai <wan.whyhigh AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] how to prove ~(A/\B)->(~A\/~B)
- Date: Tue, 27 Nov 2007 17:31:34 +0100
- Organization: Dip. Informatica
Wan Hai wrote:
Dear All.
I have two questions:
1) Can "~(A/\B)->(~A\/~B)" be proved without using classical logic,
such as A\/~A ? This can be easily proved using "forall A:Prop, A\/~A"
2) Does "~(A/\B)->(~A\/~B)" have the same power of "A \/ ~A"? Or say,
(forall A B:Prop, ~(A/\B)->(~A\/~B)) -> (forall A:Prop, A\/~A) ?
For question 1, I think the answer is no. For question 2, I have
worked on it for several hours, but haven't worked it out.
Can someone give me a clue?
Thanks a lot!
related questions are adressed in a LICS2004 paper "An Arithmetical Hierarchy of the Law of Excluded Middle and Related Principles". The answer is that (forall A B:Prop, ~(A/\B)->(~A\/~B)) is an intermediate principle between intuitionistic and classical logic.
(1) Indeed, (forall A B:Prop, ~(A/\B)->(~A\/~B)) is false in the standard realization model of second order arithmetic, this is why (1) is false.
(2) (forall A B:Prop, ~(A/\B)->(~A\/~B)) is true in the realization model in which a map f can depend on A,B:Prop, but all maps of the model are bounded by some recursive map. In this model, however,
Exists x.A(x,y) v ~Exists x.A(x,y)
is false, because in general there is no bound recursive in y on some x such that A(x,y). Therefore
is false in this model, hence not provable intuitionistic logic.
Stefano
- [Coq-Club] how to prove ~(A/\B)->(~A\/~B), Wan Hai
- Re: [Coq-Club] how to prove ~(A/\B)->(~A\/~B), Stefano Berardi
- Re: [Coq-Club] how to prove ~(A/\B)->(~A\/~B), Benjamin Werner
