- From: Jean-Francois Monin <Jean-Francois.Monin AT imag.fr>
- To: Stephane Le Roux <stephane.le.roux AT ens-lyon.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Strict Implicit
- Date: Wed, 5 Dec 2007 20:33:44 +0100
Hi,
Which value do you expect to be infered? Any expression e of type nat
could be passed as an argument.
Eg.:
Definition h:= @g 3 true.
Or:
Variable x : nat.
Definition h:= @g x true.
Hope this helps,
JF Monin
On Wed, Dec 05, 2007 at 07:34:59PM +0100, Stephane Le Roux wrote:
> Hello,
> In the example below, Coq says that the first argument of a function is
> implicit
> (despite the command Set Strict Implicit). Then, when trying to build a term
> with the function, Coq says that the first argument cannot be inferred. Is
> this
> the intended behaviour? Did I do something wrong?
> Cheers,
> Stephane
> Coq < Set Implicit Arguments.
> Coq < Set Strict Implicit.
> Coq < Definition f (n : nat) := bool.
> f is defined
> Coq < Definition g(n: nat)(x:f n):= 0.
> g is defined
> Coq < Print g.
> g = fun (n : nat) (_ : f n) => 0
> : forall n : nat, f n -> nat
> Argument n is implicit
> Argument scopes are [nat_scope _]
> Coq < Definition h:= g true.
> Toplevel input, characters 15-16
> Error: Cannot infer an instance for the implicit parameter n of g
Jean-Francois Monin Univ. Joseph Fourier, GRENOBLE
VERIMAG - Centre Equation http://www-verimag.imag.fr/~monin/
2 avenue de Vignate tel (+33 | 0) 4 56 52 04 39
F-38610 GIERES fax (+33 | 0) 4 56 52 04 46
- [Coq-Club] Strict Implicit, Stephane Le Roux
- Re: [Coq-Club] Strict Implicit, Jean-Francois Monin
- Re: [Coq-Club] Strict Implicit, Pierre Castéran
- Re: [Coq-Club] Strict Implicit, Hugo Herbelin
