coq-club - Re: [Coq-Club] Tactics for solving goals of type Set
chronological Thread
  • From: Pierre Casteran <pierre.casteran AT labri.fr>
  • To: Cody Roux <Cody.Roux AT loria.fr>
  • Cc: Areski Nait Abdallah <areski AT pauillac.inria.fr>, coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Tactics for solving goals of type Set
  • Date: Fri, 21 Dec 2007 10:15:32 +0100
Cody Roux a écrit :
You could take a look at:
Interactive Theorem Proving and Program Development
Coq'art:The Calculus of Inductive Constructions
from Yves Bertot and Pierre Casteran
(Springer)
This covers the subject in some detail. The short answer, though, is:
(1) Any tactic works just as well for a goal of type Prop or of type Set
exept eventually the elimination of the existential quantifier (for
technical reasons).
(2) You can use these techniques for programm building: if you "prouve"
the goal of type: forall l:list, Sorted_list(l). With Sorted_list(l) the
type of all sorted lists of l (i.e. sorted lists with the same elements
than l), than you have built a programm that sorts a list, and in the
same time proven it's correctness.
Yes, but consider also that, if you build a term of such a type by using automatic tactics,
you may not control the underlying algorithm, and obtain a very inefficient sorting algorithm.
restrict the  use of automatic tactics to subterms of type Prop.
Pierre
Hope this helps
Cody
On Wed, 2007-12-19 at 15:17 +0100, Areski Nait Abdallah wrote:
Hello,
I am looking for a reference which discusses
(1) which tactis can be used for solving a goal of type Set, and
        (2) covers the rationale for such tactics.
Thank you for your help,
Areski
Bug reports: http://logical.futurs.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
