- To: <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Does Function support 'forall'?
- Date: Tue, 8 Jan 2008 00:04:54 -0500
Hey All,
I did some experiments of Coq's Function and
Fixpoint,
and found Function with {measure ...} does not
support the
syntax that Fixpoint can support.
Require Import Arith.
Require Import Recdef. Definition size (n:nat) := n.
Function test1 (n:nat) {struct n} : Prop
match n with | O => True | S n' => forall (i:nat), test n' end . Fixpoint test2 (n:nat) {struct n} : Prop
match n with | O => True | S n' => forall (i:nat), test n' end . Function test3 (n:nat) {measure size n} : Prop := match n with | O => True | S n' => forall (i:nat), test n' end . /////////////////////////////////////////////////
test1 and test2 work well. Coq reports 'User Error:
find_call_occs : Prod'
for test3. But it does not give me any hint about
the details of the user error.
And the Coq manual does not explain any limitation
of Function with {measure ...}, either. How can I fix this problem?
Thank you
Jianzhou
- [Coq-Club] Does Function support 'forall'?, Jianzhou Zhao
