coq-club - [Coq-Club] Continuity of coinductive definitions
chronological Thread
  • To: Coq Mailing List <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Continuity of coinductive definitions
  • Date: Mon, 18 Feb 2008 15:14:08 +0100
I apologize if this is an FAQ. Consider these definition. I am putting the text of this message in comments so that you can just cut and paste into Coq:
CoInductive sigma : Set :=
  | Finished : sigma
  | NotYet : sigma -> sigma.
We can think of type sigma as consisting of elements of the form:
  Finished
  NotYet Finished
  NotYet (NotYet Finished)
  NotYet (NotYet (NotYet Finished))
  NotYet (NotYet (NotYet (...))  (* not yet forever *)
These might represent the running time of a machine, where the last one represents a machine that never halts. We define the coinductive predicate:
CoInductive halts : sigma -> Prop :=
  | isFinished : halts Finished
  | isNotYet : forall x : sigma, halts x -> halts (NotYet x).
Presumably, it is safe to imagine that "halts p" means that p is a finite number of nestings of NotYet which end with a Finished. To verify that this is really the case, we define a predicate "haltsWithin n p" which says that p halts within n steps.
Fixpoint haltsWithin (n : nat) (p : sigma) {struct n} : Prop :=
match n with
  | O => False
  | S m =>
    (match p with Finished => True | NotYet q => haltsWithin m q end)
end.
But now I get stuck trying to prove the lemma which would confirm my expectations:
Lemma continuity :
  forall p : sigma, halts p -> exists n : nat, haltsWithin n p.
It looks like I am hitting against a classical "trick" in Coq. How do I relate the coinductive nature of sigma to the inductive nature of nat?
I can actually imagine that the lemma is not provable without further assumptions. If this is the case, a model-theoretic explanation would
help.
Best regards,
Andrej
